Guest
·Will one of you guys have a go at this. I got this info from HKSEurope.com. Installation guide for HKS EVC EZ:
INTERNAL WASTEGATE (SINGLE PORT ACTUATOR) INSTALLATION (I assume that my Evo 5 has an internal wastegate):
Port 1: Connect to an uninterrupted intake manifold pressure source after the throttle body such as a
compressor bypass signal line using the 4mm hose.
Port 2: Connect to a source of pressurized air such as a turbocharger compressor housing (discharge side) or compressor outlet pipe (before intercooler) using the 6mm hose.
Port 3: Connect to the port on the wastegate actuator.
I need one of you experts out there to decipher this info for me. Pointing me in the right direction would do me some good. Deeply appreciate any help on this matter.
