1 - 5 of 5 Posts
I know this topic may have been posted a lot of times, i have searched threw the forums but the pictures that helps seems not to be there anymore...
Getting rather Pi**ed off and frustrated trying to remove this yesterday and today afternoon...
So far i have removed the:
3 bolts from top of bumper, 2 screws from indicators,
4 bolts from under car and the ones on the wheel arches and connecting to the air intakes...
But something seems to be stopping me to take it out from the middle?
Can someone please help our guide it threw.... maybe picture can help..
Thanks in Advance.....
when the indicators are out under them is a plug aswell that needs removing..
Then 2 bolts in each chassis leg.? Or have you removed them?
^^ yeah if its still pretty solid then you havent removed the bolts from the chassis rails. 2 on each side . you'll need and extension to get them out... either 12mm or 14mm cant remember...
On the chassis leg/rails? is this under the car our? i will check again 2moro.... hope its nice and sunny to work on the car...
bolts
the bolts are inside holes under the car about 12" or so along the chassis on each side-the bolt head is well recessed you wont see it unless you get right under
1 - 5 of 5 Posts
