Guest
·Hello, I'm Leo and I'm from Malaysia. I currently drive an evo 7 and these are the modifications I have done to the car so far ;
- HKS Super SQV
- HKS Intercooler piping kit
- HKS Cams (272/272)
- HKS Aluminium Cam Pulleys
- HKS Racing Suction Kit
- HKS GD Clutch Max
- Custom decat
- Apexi Hayabusa exhaust
- Power Timing belts
- Power 1.2mm metal gasket
I plan to get an F-CON pretty soon...BUt here's the problem,
I am running at 1.2-1.3 bar boost. Just recently I tried replacing the spark plugs, spark plug cables and added some grounding wires by Pivot. I used HKS Super Fire Racing (8) plugs and NGK cables. After installing the items, I found that the car tends to misfire at times. I don't know what's the problem and I was wondering if the experts here would like to shed some light. I'm still very new at these and I am so very eager to learn. I was thinking it could be the gapping for the plugs. I have read that (8) plugs are fine on the evo 7. If it is the gapping, how would I know if the gap is correct? I think the gap should be 0.6mm to 0.7 mm. I may be wrong about the plugs so, is it too cold? What should I do? Thank you very much!
- HKS Super SQV
- HKS GD Clutch Max
- Custom decat
