· Registered
HELP
Just went out
Put my foot down, boost, small pop, then no boost
Thought a hose had come off, no boost at all on gauge
Cannot see any lose hoses
Could the diaphram on the actuator go?
What things can I check to isolate the problem
A 2.0 normally asperated is boring
· Registered
Hi Fatman.
Sounds like a pipe to me, check them all out again.
If the actuator goes, you normally get boost, albeit not very well controlled and either loads or about .8 bar.
The other option is, the turbo has seized :( Take the inlet pipe off and see if it looks ok and can be spun by hand?
· Registered
Weebl said:
Hi Fatman.
Chears M8
Your right the Intercooler silicon has come off on the inlet side, how the heck do I get at this ?
