1 - 3 of 3 Posts
ADAPT AND OVERCOME
I Have Just Changed The Bottom Feed Pipe Off My Turbo And It Seems That The Bottom Gasket Is Leaking (the One That Goes Onto Sump) I Have Replaced With A New Gasket Does Anybody Wats Best To Seal It Thanks
Twincharger Guru
The washers on the 2 bolts that hold the pipe flange on are aluminium and are meant to stop oil going through the thread in the sump and leaking through the bolt head. Fit new aluminium washers or use copper and it should stop the leak.
1 - 3 of 3 Posts
