hello,
i got a jdm evo 8 with a link g4+ ecu, last week all 3 lights came and disnt go away, disconnected the battery for 30 mins but after just moving the car out of driveway the lights come back on... ABS lights acts normal come and goes away.
the only thing i recenty chanheed was from my stock steering wheel to a carbon fiber one... could dat had caused a issue?
i check the pump with the trottle method, it tunes on for 6 secs and shuts off normally but the ayc lights come back on after i move the car a few feet.
since i cant read codes from mg OBD2 port as my link ecu disconnects the obd any ideas what i can do to diagnose the ayc issue?
if the pump is working, tuning and ahutting down it cant be the pump failing?? so k bleed the system with new oil just im case and the pressure was fine.
any input be very helpful.
