1 - 9 of 9 Posts
Hi guys,
Ive had my 260 about a month now(another PROUD 260 owner) :D and have just come accross a problem when brakeing. If i brake when doing 60mph or over, the steering wheel shakes forward and back quite hard. The car is a year old next month and has covered 9000 miles. Ive been told it could be warped disks but i'm clueless about these things! If it is the disks coluld i get it sorted under my 2 years remaining warranty?
Cheers ,James :confused:
Hi
Sounds like warped brakes. Do a search on here for warped brakes. Lots and lots written about this as it was/is a problem. Seems less of a problem on later cars. They are unlikely to be covered under warranty.
Cheers :D
Definately disks mate...Bring it in and see if u can get it sorted worth a go...If not get a set of uprated ones on her..A lot of ppl recommend the Performance Friction setup...
Phil
sounds like the wapries mate i had this too and upgraded to performance frictions loads better
i don't think disks are covered on warrenty
saying that though i know of someone who brought a evo 6 from a dealer and had it a month and for whatever the reason the disks warped on him (he did manage to get them changed on some kind of warrenty and only paid for the fitting )
No i dont drive it hard at all and ive only done 1000 miles since ive owned it. So if it is pad deposits could drivein harder for a while maybe sort the problem?
If your onlyin derby pop down to see us we'd be happy to take a look at the car for you, and if they do require replacement we have standard discs and uprated pads in stock.
We can also supply and fit performance friction / DBA / AP's if you wanted to upgrade !
John
0115 9377200
In some cases yes. It's often a common misconception that discs are warped when in fact it's pad deposits.
1 - 9 of 9 Posts
