1 - 20 of 22 Posts
Urgent help needed please guys, travelling home from work last night in the dark and all of a sudden the most horrible screeching noise from under the bonnet and squeeling noise whenever i turn the wheel, tried to open the bonnet with the release catch and it snapped, how do i open the bonnet with out a crowbar and damaging the bodywork, any help appreciated guys whilst its still daylight:mad:
prob the plastic handle
just get a pair of pliars on the cable that attached to your now broken lever and pull :thumbup:
then order a new lever pronto
if you need more leverage, grab the cable end nippple in grips and bend them over a screwdriver or wooden block to produce a lever :)
had to do this on one of my old cars, but get a handle on order :)
nope its broken from the knuckle that is on the actual bonnet release itself, there must be some way to pop the bonnet without taking off the front bumper :shake:
nasty end for that to happen, must be a way to the catch from the underbelly?
You can see the pulley from underneath the car. Biggle - no there isn't.
I'm afraid the only way you're going to do this is to break something. I'll send you a PM.
well steve got it open after trying your helpfull advice in the PM, not to bad only cut myself 3 or 4 times, yep deffo need a new bonnet release cable now and a new mesh, power sterring fluid is empty and a nasty noise from somewhere near the top left handside as you look at the engine from the front so better get that sorted 1st off, could you please PM me the number for co-ordsport, my nearest mitsi specialist is pro tec about 20 miles away dont know if its a good idea to drive it down ro them to have a looksee, but cant see any other way to sort this out, thanks again for all the help and advice guys:smthumbup its appreciated
shocking. i appreciate its for security, but you would think theres a special tool or similar for it!
glad you got it open mate. i wouldnt drive it if i were you. i did this once after a light front ender in my teen years.
the bonnet came up and kissed the windscreen. the retaining catch had been bent slightly thats all!
if you do have to, keep your speed down and rope the bugger down from the catch to the tow eye ;)
Snap....:wallbang::wallbang:
Mine has completley jammed also, i have tried everything to get the bonnet to release but its not having it.... I have just got some sparco bonnet pins so i can completley do away with the release mechanisim.. Just need the poxy bonnet open..:wallbang:
Discussion Starter · #14 · (Edited)
you have PM mate its the advice that was sent to me, just be more carefull than i was, the mesh is bloody sharp and like most little scratches they bleed like hell, anyway found a small leak at the bottom of the power steering container, leak sorted refilled with slick 50 steering fluid and bobs your uncle, the noise i assume was from the power steering pump trying to run with no fluid in it will keep an eye on it once i get bonnet catch sorted, Hmmmm sparco bonnet pins might be the way forward depends how much the cable is gonna cost, funny thing is i cant find the snapped one anywhere under there ?:mhihi:
Discussion Starter · #16 ·
gonna take someone with more balls than me to start drilling holes in my bonnet i;m afraid:mhihi:
Discussion Starter · #20 ·
yep it did mate wasnt carefull eneugh and managed to scrape all the knuckles and the back of one hand (bled like a pig LOL) just got a new cable (£20 delivered) from dave @ EARS but sort of put off buying the mesh ( nearly £70) as im a little bit skint at the mo, will have to wait til next payday im afraid, bloody bumper off as well, oh well the joys of evo ownership i suppose:smthumbup
1 - 20 of 22 Posts
