1 - 12 of 12 Posts
Graham Cartwrig said:
My evo 7 fuel cuts when i get excited with the throttle pedle,
Your sugestions please,
Are these fuel cut defendor things any good ????????
Fuel Cut Defencers are like sticking your head in the sand; your ECU is telling you there is a problem. Better to fix what is causing the overboosting or get it mapped for that boost than waste money on an FCD.
Cheap = Turn the boost down
Expensive = Mappable ECU
Very expensive = Fuel cut defender (and blown engine)
Why is it overboosting? Have you turned it up? Might be worth trying to find the root cause but whatever you do, stop booting it and stop getting it to fuel cut, it is very bad for the engine/drivetrain.
Who told you it was running 1.3 bar?
Get an accurate gauge on it, you may find it's running a lot more.
1 - 12 of 12 Posts
