Installing my HKS EVC VI this weekend on Evo IX,
now plumping all the boost and vacuum lines as well as the HKS solenoid thing is fine, thats straight forward
However, where do i tap the power source into and also with regard to the two wires that have to go to the ECU, i beleive they are revs and speed, but i can't remember off the top of my head, if you've installed one you'll know what i am referring to how do they get secured and exactly where do they go. :cry:
thanks for any help :smthumbup
I havent installed one, but from memory you need to tie the power into a Switched ignition feed. Possibly Ciggy lighter, or around the steering cowling.
Unsure about RPM and Speed. Manual should explain all? Workshop manuals might have a wiring diagram
Thanks for your help. I have the manual and it doesn't seem a problem, its just connecting the REV and SPEED wires that i was uncertain about and the power source as well.
Guess i'll just get involved at the deep end and hopefully when everything has been taken apart i'll strike genius and all will be clear :naughty:
