1 - 15 of 15 Posts
Not sure if its the excessive heat, but my aircon is screwed. :(
I can be driving along with a nice cool breeze coming out of the vents, then suddenly it's like somone's opened an oven door as it spews out hot air. ( I notice the re-circ light goes off at this point). After a couple of minutes it will then switch to cooling again.
Happened once this morning on a journey, but on the way home it was getting progressively worse.
Any ideas?
Rob,
It never happened again, so I'm not sure what it was. I don't do a lot of long journeys, so it's difficult to check if there still is a problem, but it definitely appears to be related to very hot weather.
If you find out what th eproblem is. let me know.
Thanks,
Paul
My aircon's returned to normal now that the weather's a bit cooler.
It seemed to really struggle during the hot spell we had. I suspect it may be low on gas, which is a bit crap considering the car's only 8 months old.
Either that or Evos simply have a really poor A/C system.
1 - 15 of 15 Posts
