Discussion Starter #1
doing my cams tomorrow, done a search but cant find any info on head bolt torque settins and sequence, can any body help with this?
thanks,
dave.
Discussion Starter #3
stripped it down today, putting it all back tomorrow so not to late! thanks very much mate, your a star :D
8------6-------1--------3---------9
10-----4-------2--------5---------7
Cylinder head torque setting is 110Nm / 80ft lbs.
stage head bolts torque seqence,, to say 40Nm first...then 80Nm....and finally 110Nm.
just found another thread that says this : Mine are at 95lbs/ft gone up in 10lbs increments from 50lbs/ft .. <<< edited to say they are arp head studs
Transmission Dynamics
Out of the manual, sequence as above.
Step Operation
1 Tighten to 78 Nm {8.0 kgfm} in the order shown in the
illustration.
2 Fully loosen in the reverse order of that shown in the
illustration.
3 Tighten to 20 Nm {2.0 kgfm} in the order shown in the
illustration.
4 Mark the head of the cylinder head bolt and cylinder head
by paint, then tighten 90 of a turn in the order shown in
the illustration.
5 Tighten 90 of a turn in the order shown in the illustration.
Check that the painted mark of the head bolt is lined up
with that of the cylinder head.
Caution
(1) Always make a tightening angle just 90. If it is less
than 90, the head bolt will be loosened.
(2) If it is more than 90, remove the head bolt and repeat
the procedure from step 1.
