1 - 15 of 15 Posts
Discussion Starter #1 (Edited)
The Odyssey range of racing batteries use the Hawker TPT (thin plate technology) rolled lead grid to deliver immense cranking power and fast recharge capability. Ideal for use in high performance cars where heavy cyclic loads and harsh vibration conditions exist, the Odyssey is designed for the shake and bake environmentof the rally car where drycell pure lead technology leads the market. Originally designed for aircraft engine starting Hawker cells are exclusively used in Powervamps extensive range of aviation and military jet turbine packs.
Features
  • Maintenance free - Sealed construction
  • Lightweight
  • Vibration proof - meets MOD specs
  • Flame retardent
  • Operates from -40 to +60 Degrees C
  • Can be mounted upright or on it's side
  • Produces 2 to 3 times more power than conventional batteries
  • Up to 8 years service life
  • 2 years warranty
These are sealed lead acid batteries rather than Gel batteries, the advantage being they will take deep cycling where a Gel battery will not, apparently if one of these is fully charged and then left it will retain ~ 80% of it's charge after 12 months.
PART NO/AMP/DIMENSIONS/PEAK AMPS/WEIGHT/RRP
PC535 14 170x99x155 535 5.5 £73.73
PC545 14 178x86x132 545 5.5 £71.53
PC625 18 170x99x175 625 6.0 £71.82
PC680 18 185x79x170 680 6.7 £71.53
PC925 29 169x179x147 925 11.4 £105.85
PC1200 45 200x170x192 1200 17.2 £131.15
PC1700 72 331x168x195 1700 26.9 £177.12
POWERVAMP 3-STAGE 2.7AMP FLOAT CHARGER £49.95
All prices are then Plus VAT and £7-50 UK delivery but then minus 10% Group Buy discount.
PC535 £84.72
PC545 £82.60
PC625 £82.70
PC680 £82.39
PC925 £118.69
PC1200 £145.44
PC1700 £194.05
Charger £61.20 (postage may be cheaper if combined with a battery)
These will be direct from the manufacturer at www.powervamp.com
Connectors and wiring will also be available.
No minimum buy on these so i will run it for 2 weeks and then pass on the info you need to get the discount. Names below with model number required.
Wow
lots of numbers
But which one is a normal Evo battery
I am guessing one of the first 4 from dimensions
But it is only a guess :)
Thorak
I have a PC680 fitted if that helps.
Interested to see what connectors they can suypply, as I had to wrench mine apart to make it fit.
Dark Evo: Do you have pictures of the battery in your car???
Thanks,
Thanks Dark Evo ;)
Weebl: Can you send me via Pm the total price of the PC680 with the connectors and sended to Portugal.
I maybe interested in this but im not sure which one i need for my Evo 7 + which connectors + anything else, basically so i can just throw it straight in. :confused: Oh yeh and please bear in mind i have a slight drain on my current battery atm so may require a slighly different amperage.. Any help/info would be appreciated weebl. ;)
1 - 15 of 15 Posts
