1 - 2 of 2 Posts
hi all
i bought a set of 6 point sabelt harnesses the same as these but i dont want the crotch straps. the problem i have is that the crotch straps are attached to the clasp and they wont come out i dont want to cut the bit the goes into the clasp but dont see any way that i can get the crotch strap out of it. anyone know if i can get the crotch strap can be removed or anything else i can do
cheers MADDANE
My initial thought was to dissasemble the clasp and then remove the crotch strap connections and then reassemble the clasp. However, on seccond thoughts, although this is probably the right answer, it's not something I would undertake myself. Instead I would send them off to the manufacturer or an authorised service agent and have them perform the work so that you know it will be safe once reassembled.
1 - 2 of 2 Posts
