I have friends that own a block of apartments in Ibiza and as you'd imagine they're hungover fairly often and they swear by Irnbru.Reims said:Actually I found recently that Irn Bru worked fairly well![]()
Works for me except I take four tabs and follow up with Irn-Bru in the morning and a runny egg rollKyl3cook said:2 paracetemol (sp?) before bed, with 2 pints of water (if you can stomach it).....perfect cure.
A can of cold irn bru or full fat coke with a Kfc does the trick for meEvojkp said:Works for me except I take four tabs and follow up with Irn-Bru in the morning and a runny egg roll![]()
Sex after a good drink is a good cure as well, sweats it out you... :crackup: :crackup:GlobalGB said:Waking up between someones DD's is also a great hang over cure (as long as they're not man boobies).
I'll hold you to that the next time I'm drinking down your way.LGEVO said:Sex after a good drink is a good cure as well, sweats it out you... :crackup: :crackup:
You do that global....... :crackup:GlobalGB said:I'll hold you to that the next time I'm drinking down your way.![]()
