1 - 11 of 11 Posts
Hi All,
I am currently in the process of specing a turbo for my engine, I am looking at the GTX series turbos, I want quite a wide power band and care more about quick spool rather than top end. I was set on a GTX2876r. I am only looking for around 450-500hp, I know its a bit counter intuitive but I am also thinking of going long rod as I fancy some revs. If any of you guys have ran any of these turbos or have real world curves it would be awesome to hear what you think. I have had a look at the flow data and in the region I will be running there isnt a massive efficiency difference between these two but one has some steep lines outside the effy island. The A/R I want to run will be in the .6's. I havnt done full engine massflow calcs yet but just wanted to see what you guys have to say about these turbos.
I’m sure that’s what my turbo is (gt30) and it has a nice pull, mine is 530bhp. Make sure you don’t go screamer pipe as after 4000rpm mine is like a blue light magnet due to how noisy it gets.
Lol sounds good, I think I am set on the 3071 at .061 A/R, I'll probs recirc into the down pipe for that reason, bet yours sounds good though?
Just run loads of boost, you won’t be wasting it then down the screamer 😂👍
I would get the .82 housing as you will loose top end with smaller housing. You don’t want your car running out of steam at 7000rpm.
I don’t know what size housing mine is but if I had to choose I would go .82.
On my last car I ran a gt35 with a .63 housing and power tailed off after 6500rpm. I later put a .82 housing on and because the car made more power I didn’t notice the extra 200rpm of lag as car pulled all the way to redline.
1 - 11 of 11 Posts
