1 - 8 of 8 Posts
· Registered
yeah, was gonna do that, but after a bad experience with a T piece fitting bought from...... dare i say it again! pirtek, i went for a quote today for the follwing, 2 tails, a 15cm length of braided hose, to remotely locate a, T piece. This setup would cost me about 40 quid!
· Registered
all i used was a galv 1/8 tee and a galv 1/8 nipple screwed the pressure switch into the branch and the pressure sender into the run cost about :confused: well free as have loads laying about at work only problem is you can put temp senders there as they need to be in flow path to get accurate reading so my spa oil temp gauge is reading temp by air filter :coolsm:
mike
1 - 8 of 8 Posts
