1 - 10 of 10 Posts
Looking at getting a greddy e01 will all wiering and solenoinds etc, will i need a specific harness for the evo or can it just be spliced into wires? :)
cheers
mark
mark its only 4 wires mate live/ignition live/rpm and earth :smthumbup it doesn't wire up like the avcr, its as it says a boost controller/data logger with a fancy display screen, there is one wire to connect to the ecu (rpm) :smthumbup
awesome:)
cheers guys
found a cheep one so probably gonna buy it as its costing les than a second hand gizzmo, not that there bad or anything just like the flashy display screen :)
awesome:)
cheers guys
:smthumbup
HERE is the e-01 fitting instructions:smthumbup
awesome cheers dude, easy to fit myself you recon? take it ill need to set all the dutys etc aswell or does it have a self learn mode like the avcr and you just set a peak etc?
not sure myself bud, there is a part 2 to the install guide if you fancy a look...CLICKY :smthumbup
bit of info off greddy site.....
Even when used as a boost controller only, the e-01 has features to smooth out the boost curve. With both an auto and manual setting for both external and actuator style wastegates, the PRofec e-01 can alter its compact, high capacity solenoid valve via various RPM ranges. The large LCD screen with green electro-luminescent backlighting is easy to see. Other standard features include two preset boost levels, a timed over-take boost and compatibility with our Remote Switching System. The data display can view 3 different data channels simultaneously such as boost, RPM or any other channel inputted by the e-manage. The data can be logged up for 3 hours on an SD card while also giving warning set points and peak and hold values
awesome cheers dude just waht i needed, gonna give this a go on sunday along with my gauges, any advice from anyone? :)
1 - 10 of 10 Posts
