if anyone can help??
when i turn right ive got a rattling noise ive been told when i had my car serviced it is the down pipe on the exhaust the flexi part has calapsed?? and its touching the cross bar ,i looked at the exhaust and its close to the cross bar but the exhaust looks ok to me ,can anyone help cheers stu
:confused: :confused: :confused: :confused: :confused:
:help:
do you have lsd?
i had same problem with my 6GSR
there might be couple reasons:
a. outer cv joint
b. lsd bolts broken
c. need to put more grease into top mount of you left shock, or replace old one
on mine i did all of them, and fault was in grease :))
hope this helps
rgds
I'd go for top mounts too.
I've just put pillow mounts on - in the hope I' don't have to change them again ;)
rattle
mine sounds like its coming from the manifold to the back of the front seats could it be a loose cat or a cracked heat shield ????
the noise is a resonating/rattling only when turning right please help :hammerhea
will check
cheers m8 im going to check it on friday cheers m8 will let you know
