1 - 8 of 8 Posts
Its about time i sort the rust out underneath im after a place to:
Remove everything from underneath
Grind,sand,brush off rust
Repaint underneath & underseal
Powdercoat subframe
Fit new fuel & brake lines
Replace all bushes
Fit coilovers
Send Ayc off for refurb
Id love to do it myself but doing all that under axel stands would be a joke
Mg autos as well.
you do realise the extent of the work your are asking and its going to cost thousands for a garage to do it
to remove everything is a couple days work
to strip the entire sealant off is at least 2 weeks, then theres rust, what if it needs welding etc, as well as paint materials alone which wont be cheap
fuel and brakelines are about £350 ish i think new from dealer
bushes another 600 plus then fitting
powedrcoating again, if any parts need replacing
its going to be a huge labour bill
id say at least 4 weeks labour maybe more which will be about 6k then you have parts
buy a roll over jig and do theunder side yourself everything can be fitted then on axle stands
I've done pretty much what your man saying here not gonna say how long it took but have saved a lot of cash where it would be to go on other materials and doing it yourself you now for a fact it's getting done at your standard and not second guessing at what might have been not done properly mate it will take a fair bit of time but the rewards outweighs the cost at a garage and you'll have peace of mind that everything is spot on that's just my wee bit of input
1 - 8 of 8 Posts
