All depends how long you plan on keeping it and what your budget is. A full underside resto done right will cost thousands.
However, if it’s a keeper and you can afford it, then why not.
All depends how long you plan on keeping it and what your budget is. A full underside resto done right will cost thousands.My 8 has been mostly in storage the last 6 years but I'm now spending more time and money on it.
The biggest question I have is should I strip it back completely and do a full restore, cleaning and sealing the entire chassis. Replacing bushings, arms and such like on the rebuild and if so what ball park figure would I be looking at.
Or is it wiser to spend time and money dealing with the most critical areas where some rust is appearing and not worrying so much about areas less prone or still fine today?
4/5k for all that doesn’t seem bad to me. Are you having it painted underneath as well or just undersealed ?If it helps, I have a 05 Impreza Spec C Type RA which is having a full underneath restoration. Everything stripped, cleaned, powder coated and refitted. Brakes refurbished new discs/pads, new bushes etc.
Think the final bill is going to be between 4/5K all told.
I'm currently after a white 9 which will go through the same process.
To me, they are 15 year old cars, doing this should keep them sound for another 15
The car had Dinitrol sprayed on the underneath which wasn't a particularly decent job. The garage doing the refurb found a way of painting over the Dinitrol - rather than attempt to get it off.4/5k for all that doesn’t seem bad to me. Are you having it painted underneath as well or just undersealed ?
Painting over Dinitrol?! 😳The car had Dinitrol sprayed on the underneath which wasn't a particularly decent job. The garage doing the refurb found a way of painting over the Dinitrol - rather than attempt to get it off.
My task now is to find a protection system which is clear so it still looks minty fresh underneath.
Yeah seems a bit of a strange approach that does.Painting over Dinitrol?! 😳
Unsure what you mean, it's used every other day. I also never said it 'needed' a full underside restoration, but that I want to do one.whats the point in keeping it in storage if you still need to do a full underside restoration? might as well drive it and enjoy it
you wrote "has been mostly in storage the last 6 years" so I thought that was still the case but I see you mentioned youre driving it more now. Good idea to do have a look at the underneath and do some preventative work, many Evos have rusted away now as their owners havent taken care of the underside. If you plan on keeping the car for a long time then it definitely makes sense and will only help keep its value. If its still in good condition maybe you wont need a full restore but could do some preventative work that would be cheaperUnsure what you mean, it's used every other day. I also never said it 'needed' a full underside restoration, but that I want to do one.
When a car hits 20 years old, it's certainly a good time to look at ensuring it's good for another 20 years by looking after the bodywork before there's any problems.
