if running 1.6 bar boost on mye8fq300 ,what should i set the fuel pressure to in psi
G grantheman · Registered Joined Aug 22, 2004 · 377 Posts Discussion Starter · #1 · May 15, 2005 Only show this user if running 1.6 bar boost on mye8fq300 ,what should i set the fuel pressure to in psi
AndyF_RSX · Premium Member Joined Jun 25, 2001 · 18,129 Posts #2 · May 16, 2005 Only show this user Set it to whatever gives you good fuelling.... I would have thought that running 1.6bar you would just leave it as std (43psi with the vac pipe off) Andy
