have a full magnex, turbo back but its knocking on something when the car is started and also when releasing the clutch,the noise only started when i fitted the front pipe any ideas what its hitting ?
you sure all mountings are tight?.. has it knocked since you put the front pipe on or within a week of putting it on? .. mebbe you didnt tighten sommat enough that been the case??
SixMad,
Your pipe will b knocking on the subframe brace which passes directly beneath the front pipe , but because aftermarket front pipes r larger diametre the clearance is reduced the pipe will knock when the engine moves. However , don't panic , all u need is my spacer kit which lowers the brace 2 give extra clearance
