1 - 5 of 5 Posts
Hi folks I need another piece of advice please, I am changing the off side wheel bearing this morning but have had to totaly remove the Hub as one of the bolts is stuck beyond stuck, while removing the Hub I have managed to pull the drive shaft an inch or two out of the box, is it just case of giving it a little wiggle and push and it will pop back in?
Thanks in advance 馃憤
Brilliant thanks stu, it's now popped back in, now got to put it all back together replace the abs sensor I managed to break then it's on to the rear drop links.
good luck getting the sensor out :blah::lol:
Stu
lol that was a bstard ended up having to drill most of it out.
Still have a horrible judder/vibration though need more investigation 😡
1 - 5 of 5 Posts
