1 - 11 of 11 Posts
· Registered
Sean B said:
Is the paint heat resistant? :coolsm:
I just used ordinary car spray paint although i did put about 8 coats on and then about 5 coats of lacquer. I'm hoping that should be good enough although not the end of the world if it's not as it'll all be coming off again when i decide to have another go with the E6 intercooler.
· Registered
P11GT said:
its gonna take sum doing mick says, need to chop about with some of the brackets, make the pipes a bit more manouverable, but theres also the bigger inlets to consider on the cooler.
Cheers kev, that saved me some typing.
I think once i shorten the brackets it may just and so fit with a little fabrication. But i like a little challenge :D
1 - 11 of 11 Posts
