Guest
·I took my car today for a wheel alignement.
The place where I took it do the alignement for some Gr.N rally Evos so I though it would be easy for them.
They aligned convergence and rear camber easily, but they could not find a way to change the camber angle of the front wheels.
My TME has a standard suspension, and the camber adjustment seems to be different than the Proflex shocks that Gr.N car use.
I asked for the following settings:
-1.5 deg camber front, -1 deg camber rear and 1mm convergence in each wheel.
As they could not adjust front camber, I have a camber difference of a bit more than 1/3 of a degree between the 2 front wheels, which I don't think will be a problem anyway.
Can someone explain to me how to change adjust the front camber?
