1 - 18 of 18 Posts
Fully forged Evo 6 50k miles Fresh forge 1000 miles was fully run in on mineral oil and just been live mapped by trl developments evo specialist running a very safe 402.5 bhp and 400 ib ft torque Dino printout supplied.Je 85.5 pistons tomei h beam rods turbo technics 80series rebuild 9 turbo only done 1000 miles. Hks turbo j pipe Braided turbo lines 3"custom elbow with screamer pipe Turbo jacket cosworth rod bearings cosworth main bearings arp rod bolts arp main stud kit arp head stud kit cosworth 5 layer head gasket new water pump new timing belt balance belt timing adjuster veneir pulleys hks plugs 8mm plug leads hks 272 cams springs and retainers full 3" custom exhaust from turbo bk , Megan exhaust manifold time attack inlet manifold polished fuel rail rc750 injectors sard fuel pressure reg braided lines Exeedy clutch and fly wheel walbro fuel pump Toyo inter cooler and hard pipes 52 mm toyo radiator toyo 19row oil cooler stoney radiator hoses sick speed hornes 3" hks induction pipe greedy filter baileys dump valve aircon removal battery in boot r spec boost controller hell clutch line hell break lines momo steering wheel cold air feed with filter box cusco coilovers cusco 3 point strut brace cusco carbon fiber rear brace white line under engine brace fully poly bushed probs more to list but you get the idea !Has 6months mot but has cracked wind screen All brembo breaks have been refurbed blue and look great Engine is ready for 600bhp+ with rite turbo Car will come with the white oz wheels in pics 18"oz with new falken tyres Imported in 2009 with docs to prove Full service from Norris designs when imported and has only done 5k since then.Body work is in excellent condition few little stone chips but to b expected , all undersealed and protected , no ware on seats which is unusual on these. The engine cost £5000 in parts that's just for parts not building it. The turbo manifold and inter cooler was £2000. Car now has teincoilovers which have motors on them and can be adjusted from inside the car. The Ayc pump has currently seized and I have been quoted £200 to get an overhaul on it the car drives normal still with no issues. Looking for another car px any queries or more pics of engine build and car please contact Andy on 07557979926 thanks.
I've adjusted your ad, to make it more readable.
Je 85.5 pistons
tomei h beam rods
Hks turbo j pipe
Braided turbo lines
Turbo jacket
arp rod bolts, arp main stud kit and arp head stud kit
new water pump, timing and balance belts, timing adjuster and verneir pulleys hks plugs 8mm plug leads
hks 272 cams, springs and retainers
full 3" custom exhaust from turbo back ,
polished fuel rail
rc750 injectors
sard fuel pressure reg and braided lines
walbro fuel pump
19row oil cooler
3" hks induction pipe and greddy filter
baileys dump valve
aircon removed
battery in boot
hell clutch line and brake lines
momo steering wheel
cusco coil overs and 3 point strut brace
cusco carbon fibre rear brace
fully poly bushed
probs more to list but you get the idea! Has 6months mot but has cracked wind screen. All brembo calipers have been refurbed blue and look great. Engine is ready for 600bhp+ with right turbo. Car will come with the white oz wheels in pics 18"oz with new fallen tyres. Imported in 2009 with docs to prove. Full service from Norris designs when imported and has only done 5k since .Body work is in excellent condition few little stone chips but to b expected , all undersealed and protected , no wear on seats which is unusual on these. The engine cost £5000 in parts that's just for parts not building it. The turbo manifold and inter cooler was £2000. Car now has tein coilovers which have motors on them and can be adjusted from inside the car. The Ayc pump has currently seized and I have been quoted £200 to get an overhaul on it the car drives normal still with no issues. Looking for another car px any queries or more pics of engine build and car please contact Andy on 07557979926 thanks.
:smthumbup
It's one of those Evos that tempts people searching for an STi into Evo ownership... :lol:
No wear on seats!
Whats that on the drivers seat side bolster?:shake:
1 - 18 of 18 Posts
