1 - 8 of 8 Posts
hi all have ford escort n reg prob with front wheel. well hub me thinks took wheel of and i can move hub up and down and from side to side me thinks there is a prob. any ideas
Wheel bearing m8, ;)
Does the brake pedal go soft when you are driving too??
doesnt seem to but i did notice brake peddle every know and then really throws it self back at you but i put that down to disc moving about. you can take hold of hub and just move it all over the place
I agree - sounds like the wheel bearing. Should be able to get a reconditioned one fairly cheaply - have you got a friendly mechanic who can sort it for you?
If it is a wheel bearing then it will probably need pressing in. You can't get re-con bearings :eek: but new ones aren't expensive. A small workshop would probably supply and fit for less than £100.
1 - 8 of 8 Posts
