After some research I have got the rolling radius of the tyres and gear ratios and I think these are the correct max speeds in each gear.
GSR
1st 40.56
2nd 60.69
3rd 82.28
4th 107.26
5th 135.93
6th 170.26
GT
1st 42.87
2nd 61.23
3rd 82.68
4th 108.94
5th 156.89
This is assuming a 7400 RPM limit which I think is about right, but you get the idea.
Essentially the first 4 gears are the same in both cars, with the GT having 5th somewhere between 5th & 6th on the GSR.
For comparison 1st, 2nd are identical to and Evo VI TME, 3rd & 4th are slightly lower making it a slightly closer ratio gearbox. 5th is the same. So those worried about the GT being inapproriate for a daily drive due to gear ratios have nothing to worry about.
This means that 90-100 in top is 3900-4400 in the GSR and a slightly less fuel efficient 4200-4700 in the GT. But at motorway cruise speed there is only 300rpm in it....not too bad!
Ben
GSR
1st 40.56
2nd 60.69
3rd 82.28
4th 107.26
5th 135.93
6th 170.26
GT
1st 42.87
2nd 61.23
3rd 82.68
4th 108.94
5th 156.89
Ben
