1 - 15 of 15 Posts
· Premium Member
Tried to repair the folding mirror mechanism which seems stuck on my offside mirror.
So I was unable to find a guide with photo's that worked, I will be doing a strip down guide when photobucket is feeling more friendly.
I cleaned all moving parts and checked motor/gears were free and not damaged. Individually they seem fine but it still seems to bind up when the vertical shaft with the 2 gears engages, it seems to jam against the plastic housing as pressure is applied.
I have a suspicion that if I take a bit of a coil off the spring that puts pressure on the joint between the base and the mirror, essentially the part it pivots on, it will move more freely and the gears might not bind up.
I think it may be a relatively cheap fix for something that doesn't seem repairable... my first impression is this spring is putting far too much tension on that joint I can't see why it needs to be so strong.
· Premium Member
Discussion Starter · #2 · (Edited)
As you can see everything was stripped and cleaned, removed all the old crappy grease
And rebuilt with some of the white water resistant grease. I noticed the bit that pivots where the spring is was very tight so when you flip it over I used lots of grease and with everything stripped I manually moved it back and forth to work the grease in. once built back up though it was obvious there is an issue with the gears binding.
· Registered
· Registered
Hi,
Am from india. I got same mirror to be installed in lancer, but i had one problem, the motor was not working. so i removed the casings and made the motor to work freely. and i greased the gears, all good and no wornout. but if i checked in bench. only 30% is working open /close. the motor stops it seems I think the relay in the mirror got weakened? What you say
also, Does this unit run directly without seperate power folding unit? my mirror has the same in picture as you had. please . looking help:wallbang:
· Registered
Hello dear
How much is the volt on the motori have another issue
· Premium Member
No point starting a new thread. Just dismantled n/s mirror from my VI.
Looks like the plastic gear on the worm screw is worn, you can see it at the top. Symptoms were clicking when trying to fold/unfold mirror.
Would anyone know of a source of replacement gears, or even if a 3d printed one would be strong enough?
Circuit component Wood Electrical wiring Gas Audio equipment
· Premium Member
I spent quite a bit of time and a few quid trying the same thing with the evo X mirrors, common failure was the actual motor, but couldnt find anywhere to get a suitable replacement. I found the originals, special order for :Mitsi: The same could be bought separately, but min order of something like 10,000. Tried a few other 12v motors that looked identical, but different specs, non worked sufficiently well....Gave up
· Geekmapped.com
Evo X FQ330 SST
If not then try to get the ear of a friendly dealer and get them to check out the part number for mirror repair kit. I bought one about 8 years ago and took about 20 mins to fit. Comes with new motor mechanism in a bolt-in "chassis".
1 - 15 of 15 Posts
