I wonder if anyone can help me?
I've recently bought a 2nd hand HKS Intercooler pipe set and I'm just in the process of measuring it up for some Red Samco's before I fit.
Only prob is, I dont have any of the original joiners and hope that someone out there may have a list or know what sizes I need!! :confused:
sizes
Hi
The intercooler sizes are 60mm ID, (bought and fitted this size, it is a nice tight fit) and the turbo outlet I think, is 45mm ID (although not exactly sure on this), the original pipe has a funny twist in it even though it looks like a 90 degree bend.
Cheers Paul
not sure if sussex reims did all these pipes recently, may be worth dropping him a mail, or wait for other replies.
Sorry cannot help with lengths.
Looking at the hoses u r missing i can provide u ID 's for the lower right IC (looking from the front of the car) and the IC to inlet plenium hose as i replaced these with Samco's.
I will get the tape measure out 2moz if no1 privides these in the meantime as car is away now.
Toby :D
doh...on a 2nd look they are the only 2 u need ne way.
For my IC lower connections the left and right where identical in ID and curveture so maybe the same measurements as the one u have for the left will do for the right?
I used 80mm ID for the inlet plenium feed still using the standard plastic bend. If the hardpipe is not able to connect to the 80mm ID u will need a reducer. Samco do these.
Thanks once again SUSSEX - I'm changing them all to red :coolsm: but have been a bit :confused: baffled why the few hoses that came with it are so long when they neednt be!! Not helped by the fact that they arent all there too :rolleyes:
Any further help would be really appreciated!!
