Just found this on the internets, can someone please confirm if it's accurate. It it is then it should finally put rest to how to spot the MR cams. :)
Your picture is talking about the cam lobe height though, isn't it Grant?
Aren't the top two pictures specifying the diameter of the non-lobe mouldings on the camshafts?
Holy thread resurrection!!
So I've got a couple of cams which could be from a 7 or could be MR's
[/URL][/IMG]
Looking at the images at the top of this thread I'm none the wiser
Looking at my cams,
My Exhaust (notches in the end of the shaft) has the 2 rings next to the nut the same size.(none of the above match that)
My Inlet has the rings go, 'small', 'large' then nut.(Matches 8MR cam)
Numbers stamped on the ends are..
INLET: P3013011044
EXHAUST: 301302047
Both have a letter P stamped too.
Any ideas please?
cheers
