Few problems left to sort with the car so gathering all the stuff for when winter comes around i need parts or info on where to go to get these things ordered
O/s/r brake line corroded = full set (under car)
Fuel filler neck corroded
N/s/r outer bush slight play = where to order Polybush's all round
Ayc pump leaking / no fluid in reservoir = who to go to for refurb
Both rear chassis legs rusty
Fuel/brake line around tank rusty
N/s/f droplink gaiter split
Front lower cross member rusty
O/s/f brake backing plate missing
Engine sump leaking oil
O/s/f abs sensor touching wheel
Rocker cover leaking oil
Handbrake needs adjusting
Oil temp switch routed close to wheel
Any info would be appreciated thanks
full car set of brak lines, every line including all clips and bolts frommain dealer, they come pre bent about £300 all in
most can be bought new from dealer still like bushes etc, if its the outer 2 spherical bearing type keep standard items not poly bush
I was under the impression they stopped supplying parts for the evo.
Thats great news though thanks will give them a call
