Hi guys,
removed the rubber boot off the clutch slave cylinder on my evo 6
the inside was wet with fluid, does this indicate a faulty slave ?
as ive had problem with my clutch pedal losing pressure, even after bleeding
& not being able to select gears.
thanks in advance:coolsm:
