Guest
·W.S.C.U.
Water Spray Control Unit
As we all know the Evo6 has a manual Water Spray Switch next to the hand brake.
But who knows when to use it and for how long?
The time you really need to use it your to busy watching the road/track/rev counter and changing gear!
We (at Power Engineering) wanted to make this system automatic.
We will shortly be offering a very clever and intelligent control unit that will do it all for you...
It should be available early spring, just in time for the summer ( we don't have! ).
The control unit monitor's Airflow and Charge Air Temperature and works out when to operate and for how long.
It also has a low level reservoir indicator and carries out a system's check's on every start-up( including a fault code read out if the system has found a problem ).
The next project were looking hard at is .....
We have found evidence of an anti-lag strategy in the code of the standard ECU.
However it will require a lot of testing (more overtime) and we are not sure if it was ever intended for use.
We are continually trying to improve our Evo.
If you think we could help you with yours let us know.
My first post so be gentle with me....
Regards
Mervyn
Regards
Mervyn
