Hi gyus
I recently faced the described problem.
When the car is standing still, with the engine running, it's getting hard to engage first gear. Also when I'm trying to engage first gear(clutch pedal fully pressed), the car is being pushed slightly ahead.
Reverse, is even harder to be enaged! In order to engage reverse i have to select forth or fifth gear firstly and then switch to reverse.
Gearing up or gearing down is not a problem(althought gearing is a bit tighter than normal) when the car is running or when the engine is not running.
Accordign to your exprerience, what is the problem ?
Regards
Nicolas
Regards
Nicolas
