Brand new in sealed box. I haven't opened this.
Bought for a stroker project that I am not proceeding with.
This is the SD version, rated for 520lbft officially, but unofficially it handles significantly more so long as you don't launch it with much over 600lbft.
It uses a strandard strength pressure plate meaning it has the same pedal weight as standard, despite the much higher torque rating.
The clutch comes supplied with the clutch release bearing. I believe the clutch is suitable for use with the 5 or 6 speed boxes but I need to confirm this.
£950 delivered which is much less than you will buy it for from any UK retailer.
(I brought it in from the states and am merely trying to recoup my money after changing my mind!).
