1 - 20 of 154 Posts
BAD BISH
Finaly managed to get my head done:
Special thanks to Ross Sport for almost all parts :thumbup:
EVOLUTION VIII HEAD SPEC
- 4G63 Head work, port & polish
- Intake Manifold, port & polish, red powder coating
- Intake Manifold Gasket OEM Mitsubishi
- Exhaust Manifold, port & polish
- Exhaust Manifold Gasket OEM Mitsubishi
- Kelford cams 272, 11 mm valve lift
- OEM Mitsubishi Cam seals
- Ferrea +1 mm Inconel Inlet valve
- Ferrea +1 mm Inconel exhaust valve
- Ferrea Valve guides
- Ferrea Valve locks
- Ferrea Valve stem seals
- Kiggly Racing high presure Behive springs
- Kiggly Racing Titanium retainers
- BDL Adjustable cam gear
- ARP Cam gear Sprocket bolts
- ARP Cam tower bolts
- Intake & Exhaust studs & locks
- Forced Performance „Black" Turbocharger
Dual ceramic ball bearing, 1,7 bar WGA
- Ross Sport Turbo Elbow
- Turbo Elbow Gasket OEM Mitsubishi
- NGK Spark plugs, Iridium BR8EIX
- Valve cover, powder coating - Jet black
- Valve cover Gasket OEM Mitsubishi
BAD BISH
thanks, its my bedroom now. wife kicked my out of her bed :lol:
BAD BISH
:mhihi:
yes, it's most likely that one day a car will drive out of my room.
To bad that I live in a 11 floor building :crackup:
Reactions: tully-o
BAD BISH
:crackup: eagle eye!
I think it was rather the turbo :mhihi:
BAD BISH
Thanks guys ;)
Still need to ceramic coat the exhaust manifold.
Would any one suggest to coat it from the inside?
I'm bit afraid of that because it might chip off and fall in to the turbine and cause damage. (?)
How dose Zircotec do it??
acting daft since 1969
Can i just ask WHY ?? is one of the valves open further that the other in one of these pics, 5th one down further valve to the right
BAD BISH
they are all the same opened, must be the angle I took the pic.
Every thing has been checked and measured for clearances. :smthumbup
Looks very good did you have the ports matched to the manifold, also was the head flow tested, if so what gains did you get ?
yes, the manifolds match to the head channels so there is no step you can feel when you go over with the finger...
and yes, it was on the flow-bench tested.
Reactions: Jacko4RS
BAD BISH
Discussion Starter · #16 ·
Why keep it in a drawer when you can watch it all day long :)
BAD BISH
Discussion Starter · #18 ·
yes, of course, just need one forged 2.3 short block :D
BAD BISH
Discussion Starter · #19 ·
Here a few fresh pic of my and my friends car.
LOVE the yellow color on the GT-R :headbang2
Reactions: ND4SPD
Zero Fighter
You need carbon splitter and carbon side skirts !
By the way ,
Je li jos uvijek cekas na poljubac? :D
1 - 20 of 154 Posts
