evo4
239 Views 3 Replies 0 Participants Last post by  Evo4Jon
wen i rev the car and take my foot of the throttle i can hear a rattle coming from the manifold are any one had this problem
Patrick,
Sounds like one of two things, one cheap and one expensive.
The cheapest, and most likely is just a loose heat shield. There's one over the manifold, and on my stock EVO 1 exhaust, about 3 surrounding various parts including the cat.
The expensive option would be the cat breaking up and rattling it's way out down the system.
From your desription, I think you can rule out the cat as you say the rattle is from the manifold area.
Cheers,
Mark
Hey !
My Evo4 does ht e exact same thing.
It sounds like a tinkling sound right ?
Like a vibrating heat shield but I have removed all of my down pipe ones and its still there !
I also removed the top one (which goes rusty)
The only one I haven't removed is the one near the oxy sensor.
Does your car also give a little tinkle when you switch off too ?
If you find out what the cause is then please email me at....
[email protected]
Jonathan
BTW: I have removed my cat so its not that either !
Jonathan
