1 - 5 of 5 Posts
hi
looking for a evo 2
went to look at one today not atall bad
apart from crunch when put into top gear
is this common fault
what sort of price to put gearbox right
i would of bought car apart from gearbox
steve
5th gear Synchro can be done with box still in car but is a fiddly job....to get the whole box rebuilt can be very costly depending on whats needed....if its just the 5th gear though not too bad.
Ian
No Probs :)
PM Petbeemer on here i believe he has done an in-car 5th synchro swap...and if you search for his posts in gearbox section i think he posted a 'how to guide'....also check out the transmission section on http://www.vfaq.com/index-main.html .....while there boxes are not quite the same as ours the basics are the same....i still havent plucked up courage to tackle my 2 spare broken boxes but if you pm Ned Flanders on here he has done his. If you split whole box make sure you get it all shimmed back correctly or it wont last long as many people have found out!.... i dont mind rebuilding engines but im still wary of gearboxes :blush:
HTH
Ian
1 - 5 of 5 Posts
