I got a service a couple of months early and the service period (miles and months) hadn't reset. It came on the other day so I reset it and it said 2600 miles/8 months. I tried to clear it again now it says 2600 miles/ 20 months!
Is there a way to reset properly? Or even set the number of months manually?
Thanks!
:mitsi: dealers use their diagnostic linkup to correctly reset the miles / months.
Every time I play with the rest button - I get 12 months added, just as you found out.
https://www.evolutionm.net/forums/evo-x-how-tos-installations/336950-need-how-turn-off-reset-periodic-inspection.html#post5949582
To return it back to 8 months, change the servicing schedule temp to EU6 (or anything) then return it to EU10. Once those 2.6k miles or 8 months run down - then do another reset to +10k / +12 months. This is just a quick hack way to stop the service light - otherwise as Jabo indicates - you need the linkup to reset to zero properly.
https://www.evolutionm.net/forums/e...ff-reset-periodic-inspection.html#post5949582
That looks crazy complicated for a simple thing! But that's great thanks, I'll give that a go and if I break it (which I probably will) I guess I'll just have to take it to Mitsu, which I hate doing cause they're crap.
Hopefully they could manage that though!
