Hi just wondering if anyone could help.The head unit comes on fine and plays music for a few minutes then for no reason the sound just stops.Then when I turn the car off and back on again it does the same again works for a few minutes then the sound stops.I think it's the amp but if anyone has any ideas what it is or where I can get another oem rockfodfosgate amp from would be grate.
Regional Organiser
It is more then likey a fault with the amp but it's also worth checking the wiring to the speakers to check it's not damaged and causing the amp to over heat.
Regional Organiser
Not necessarily.... It could be the internal temperature not the external temperature of the amp.
