I was trying to replace the front bulbs with LED ones, read the manual and found this old thread
http://www.lancerregister.com/showthread.php?p=3712052#post3712052
http://www.lancerregister.com/showthread.php?p=5601635#post5601635
Did the steps / and more - Turned the wheel to full lock, removed the bottom 3 screw tabs, a 10mm hex tab and popped a push tab on top of the arch - and further 2 push tabs directly underneath the front.
That arch liner is very stiff plastic that wont pull away/bend, and there is no room for it to bend to. I can perhaps make a 1.5 to 2cm gap and no more, this is bordering 'excessive' force, and will shred my hand.
The other way is to jack the front up and remove under-tray, but there's the O/S is packed with an oil cooler which gives another round of access problems.
Hope I don't have to remove the whole wheel then the arch liner. I'm thinking my arch liner is different.
Thanks, I guess I'm jacking the car up for more access, think one of the tabs that's holding in the bumper isn't unclipping. I don't want to break it.
It's a piece of **** just be prepared to get cut arms and knuckles 😂 oh and make sure you don't put a longer than usual bulb in like I did and popped that little bulb cover off in to the headlight
Sent from my F5321 using Tapatalk
Easiest way is to pop the clips and 1 bolt at the front of the inner wheel arch and squeeze your arm in.
Sent from my SM-G935F using Tapatalk
