1 - 5 of 5 Posts
What size/offset wheels and tyres are you running?
Standard spec just 25mm spacers and lowering springs rear arches catch slightly.
Before you cut/roll the arches you should check the rear camber. They should still just fit. I'm running 9.75 et20. These in theory should poke out more. I'm pretty low with no catching. Maybe check rear camber. Maybe a little negative camber (but still in scope) may be enough to stop catching. Also have you checked where on the arch is actually catching?
1 - 5 of 5 Posts
