1 - 17 of 17 Posts
2003 Mitsubishi VIII RS
Imported Into The Country February 2017
2.3 Stroker Build Running Owen Developments GBT 6176 Turbo
626.7 BHP / 590 FtLb
Engine
2.3L Norris Designs Short Block (100mm Stroker Camshaft, ND 85.5mm Pistons, Manley 150mm I Beam Rods, ACL Bearings, ARP Main Stud Kit)
Head Rebuild (Kelford 272 Cams, Supertec Valves, Kiggly Springs, Kiggly HLA Pressure Regulator, 3mm Hydraulic Lifters, Supertec Valve Guides, Supertec Valve Seals, Norris Designs Head Bolts, Norris Designs Head Gasket)
Link G4+ ECU (Running Knock & Closed Loop Fuel Control)
Owen Development GBT 6176 Turbo
Zircotec Coated Exhaust Manifold
TIAL Wastegate & Screamer
RossSport 4” Intake Kit
K&N 6” Cone Filter
Pro Intercooler
HKS Cam Pulleys
Fluidampr Viscous Damper Bottom Pulley
JMF Race Intake Manifold
Injector Dynamics 1050 Injectors
Walbro 450 Fuel Pump
Radium Fuel Rail
Fuel Lab Pressure Regulator
Spoolinup Coil On Plug Ignition
Radium Oil Catch Can
Mishimoto Oil Cooler
Greddy Radiator & Slim Line Fan
Kakimoto GT 1.0Z Exhaust
Balance Shaft Delete
Drive
5 Speed RS Close Ratio Gearbox
Carbon Synchros
RS Differential
Ross Sport Torque Tube
Exedy HD Twin Plate Hyper Clutch
Carbon Fibre Prop Shaft
Wheels, Brakes and Suspension
Wedsport TC105X Wheels
Meister R Coilovers
Front AP Racing 6 Pot Brakes
Yokohama AD08 Tyres
Exterior
Gialla Front Bumper
Chargespeed Front Wings
APR GTC300 Carbon Rear Wing
APR Front Carbon Splitter
APR Carbon Mirrors
OEM Evo 9 Rear Bumper
Carbon Fibre Rear Diffuser
Carbon Fibre Vortex Generator
Carbon Fibre Side Skirts
Interior
Recaro Pole Positions
Takata Drift III Harnesses
Nardi Steering Wheel
Internal Roll Cage
Defi Pillar Pod Gauges
371933
371934
371938
371939
371940
371941
371942
371943
371944
371945
Like has already been said, those wheels really suit it.
That must be ridiculous with the short ratio boxo_O
Stunning build.....how long has it taken you to get it up to that spec?
1 - 17 of 17 Posts
