1 - 10 of 10 Posts
· Registered
i have no idea, as Nick @ NR autosport sets mine up for me...i doubt he will volunteer his personal settings but if you take it to him he can work the settings onto your car i am sure.
· Registered
See if this helps:
This setup is using on track AND road - so will count as mild track settings and aggressive road settings.
I am running Whiteline Coilover kit with adjustable top hats, front and rear sway bars.
Car is lowered of course, but using the national development car they found that too low induces understeer, so not exactly sure on where we settled at, but once it was very low it was creating much understeer - better since rasied again.
FRONT:
Neutral toe
Camber: -2deg33
Caster: +4deg
REAR:
Neutral toe
Camber: -1deg04
Track shockies settings
Front: 10
Rear: 8
· Registered
I assume to mean cambre rather than toe?
The standard suspension to supposed to be good for a max of -2deg up front.
Whether or not these are consider fast/road or not, I dont know. But, my settings are the following. It has made the car more neutral over stock and it suits my driving style.
front = -1.4 cambre and 0 toe
read = -1 cambre and 1mm toe in.
Mark
1 - 10 of 10 Posts
