Guest
·Ordered this am from Coordsport HKS Super Drager |PLS| Ralliart Panel Filter |PLS| ARP Bolts.
Asked Phil about the MOTEC ECU - he put me off by saying that for everyday use it would probably be unsuitable. In that cold start would be a pain etc.
However, the Ralliat Sports ECU for the SEVEN does not require a boost upgrade as its all done by the new ECU. This then is the way to go as far as I'm concerned. Will decide after the ARP bolts have been fitted.
Has anyone else with a SEVEN swopped ECU's? if so can you offer any thoughts?
