Title wrong, its a Vl not a V doh.....
Evo Vl
Running AP's front (6 pot) 332mm
I need 3 sets of suitable alloys, slicks, wets & DG03's
Need to clear AP's & arches
Do I go 17" or 18" ?
What offset, PDC etc....& max tyre width with no rubbing ?
Any advice greatly appreciated
Chris
I run this brake set up on 17's, from my experience 18's were not as good in terms of driving experience as 17's. But I guess it depends on how the car is set up, mine is fast road, occasional track day Geo settings, Ohlins and uprated ARB's. Standard TME alloys and 17x8.5 et35 alloys, but alloys can be a sticky point dependent upon design of spoke and offset. This works for me....
Sent from my SM-G935F using Tapatalk
NR555
I have the 332s on my VII and can fit standard VII alloys
Reactions: Mellow
17 inch wheels work well on evo V /VI , brake clearance should be fine on 330 mm brakes too , on et 35/38 it's possible to run 10mm spacer too but you should then run longer wheel studs . Tyre wise 235/45/17 or 245/40/17 work well on et 28 . Hope this helps .
