Hi!
These are the settings that I get from Graham Goode Racing for EVO V.
FRONT. Toe -in -3
Camber -1deg 00min |PLS|-30min (difference between right and left wheel less
than 30min)
or -2deg 00min |PLS|-30min
If arrow on top bolt that connects strut to knuckle. 1. Faces inboard then
camber is -1.00
2. Faces outboard then camber is -2.00
REAR. Toe-in mm 3|PLS|-2
Camber -1deg |PLS|-30min (tolerance is same as front)
Might be useful for someone to have them!!!
Regards
MAXI
