hi guys recently developed a problem on my ego 8, turn the key all electrics work as they should, battery is full and good as i tried jump starting it now when i turn the key i hear the starter click but doesn't turn, its defiantly clicking as i had a mate turn the key while i had my hand on the starter and it clicked but isn't cranking. So i replaced the starter for a brand spanking new one and much to my grief same damn problem it clicks but doesn't turn.
i also removed the ignition switch and tried turning it fully with a screw driver while it was out and it made no difference, i only removed it as some folks had the switch worn out but mine does not make a difference, but i can see a spark when i turn the key from this switch could this be a sign of a faulty switch??
can the relay being faulty also cause this?
